Old 10-04-2021, 11:49 PM   #2
chromecarz00
Originally Posted by 986 Boxster View Post
Clucking could be your CV joints or the struts, are your boots OK? It`s hard to guess, you should go to a qualified mechanic and get an expert opinion. You have to many things going on, I`m pretty sure you need new struts and mounts, your car is wobbling/bouncing at high speed and that is due to worn struts, anything else you would have to look at it to see if they are worn out or bent, like a bent control arm or a torn boot which the CV joint is probably damaged, etc. GL.
I think this is what I'll end up doing if I don't get any actionable Intel on how to diagnose... But it just feels like struts would be the answer
chromecarz00 is offline   Reply With Quote
