Old 09-28-2021, 04:28 PM   #14
djw8282
djw8282's Avatar
Originally Posted by PaulE View Post
I think whatever rubber/plastic that gasket is made from may experience some kind of permanent shrinkage as it ages that can't be fixed by soaking in hot water. I had a similar experience a few years ago. One of the studs on the back of the emblem broke off as I was removing it to fix the gasket. I ended up buying a new gasket and emblem, and the hot water trick worked perfectly on the new gasket. Good luck!
Good point. I'm wondering if this "new" gasket I purchase has just been sitting around a warehouse and is harden to the point it won't expand 🤔
djw8282 is offline   Reply With Quote
