Old 09-28-2021, 12:06 PM   #126
ecp
Originally Posted by safesaxbdd View Post
Thanks, ecp. Fingers crossed it's ok. I actually couldn't get the throttle body off - the bolts wouldn't come loose even after I sprayed free-all on them - so tomorrow I'll let another mechanic take a look and see what's what.
You can leave the throttle body on the plenum. Just undo the AOS hose that goes onto the plenum, the rubber boots that attach the plenum to the runners and the one bolt that mounts the tb to the engine. It’s better to do it this way so you don’t compromise the seal between the throttle body and plenum and it gives much better access to the intake runners to get the oil out
ecp is offline   Reply With Quote
