Gents,
I ordered the URO brake master cylinder from ******************************** and installed last week.
prior to the install i could not push any fluid to the rear brakes. fronts oddly were fine.
once new m/c installed, i was able to pump the fluid through, then bleed with motul 5.1
all good so far.
i was going on a bit of a wild goose chase with new abs units, brake booster upgrade (which my 2000 boxster S was built in late 1999 and was on the cusp of gen 1 986 vs gen 2 986.
hammered the brakes a bunch of times in the dry and rain this past weeks to activate the abs. I hadn't really got the abs to work in months, maybe years... and last major drive was in a snow storm in Feb so when i pulled it out in the spring and the rear brakes seized, i was somewhat baffled esp with a 60,000 mile boxster
fixed for now!!
