Old 09-23-2021, 03:23 PM   #121
safesaxbdd
Just got the car back after AOS replacement. Did not replace the RMS. It wasn't showing any fault codes on OBDII. I fired the engine and it struggled to turn over, then white smoke out the exhaust again. Shut it off. Not sure if this is normal behavior after a swap?
Doesn't appear to be dripping oil but I'll check in AM again.
safesaxbdd is offline   Reply With Quote
