Good to know the alarm box is dry, finding it wet can lead to weeping and gnashing of teeth.
When does the fuse blow? Is there any correlation to the doors being locked?
Can you open / close the doors with the fuse not blowing? If so, do the windows move up/down as they should when closing / opening the doors?
Maybe try disconnecting the horn, if it is not working perhaps it is shorted causing the fuse to blow (a wild guess).
There are many connections / switches / motors tied to the alarm system. It will help if you can narrow it down. Are the two alarm codes still present?
