Old 09-21-2021, 04:35 PM   #2
Stl-986
By ecm you mean the DME right? If so, that is in the trunk. The immbolizer is what is under the seat but since the car starts that is most likely no the issue. Issue is most likely the ignition switch which are very common to fail and cause weird things but you said you already did that.
Didn't know you could control the spoiler with durametric. You can turn the light on/off but I dont remember seeing where you could active it up or down.
Any chance the cluster has been upgraded to one of the 996 versions?
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
