Old 09-16-2021, 12:29 AM   #1
Ebell914
2000 S, 88K Miles in N Carolina, $13k
Gonna Try This Again. :-)
2000 Boxster S in Ocean Blue Metallic
Asking: $13,000
Saddle Full Leather Interior and Metropol Blue Top
Stock CD player with Infinity Kappa 462.11 in dash, JL audio C1 5.25” in doors
JL Audio RD400/4 channel amp and 8” W3 sub under dash in custom box
Other options include:
Traction control
On Board Computer
Ashtray Delete
Heated seats
Wind Deflector
Rear Storage Box
Cruise control
Very stock 3.2 with 88,000 miles
Great running, owner for last 8 yrs, bought at 53,000 miles and has had regular oil changes with Blackstone reports after each- always good results with no increased levels of internal materials or contaminants.
Included with the sale is a Durametric diagnostic tool with only 1 of 3 activations used (the one being for this car).
Previous owner replaced clutch, RMS and IMS at 52,000 miles, LN Engineering ceramic bearing.
Recently replaced (with OEM parts):
Water pump
Drivers door lock assembly
Top Center Windshield Microswitch
Front and rear trunk lift supports
Driver Window Regulator
All 4 shock mounts, bump stops and bellows
Bilstein B6 Performance Dampers (not OE)
Brembo cross drilled rotors and OE pads- front and rear
AOS
Driver side Oxygen sensor 1
Original iridium spark plugs and tube O-rings
Toyo Proxes tires at 83k
Body/paint in good shape,
very slight impression in front right quarter panel
Original Metropol Blue top in good shape- Vinyl window was replaced 5 years ago
Up/Down mechanism works properly
There was a leak coming from the steering rack, but the rack has now been replaced with a very low mileage (30k or so),OEM unit.
I have all records/receipts for me and the previous owner to validate all work mentioned. This is over 10 years of history. I just got a John Cooper Works Clubman for my d/d, so I never drive this one. Thanks for reading!
Car is located in Charlotte, NC. Feel free to reach me via call or text at 980-833-4976 or email at erik@belluccinet.com .
Current: 2000 Boxster S....2018 Clubman JCW
Previous: '71 914 2.2 - TX license plate: "E-GO"....'73 914 1.7....'74 914 1.8....'73 914 2.0 - Saturn yellow with all original 2.0 options- R.I.P..... '74 914 1.8 with 916 body kit.... '72 914 1.7 - my very first car
Also: '09 Cooper Clubman....'90 Miata.... '80 MGB.... '76 TR-7
Ebell914 is offline   Reply With Quote
