Old 09-14-2021, 01:01 PM   #11
Silber
Originally Posted by Quadcammer View Post
that case is definitely not going to be usable. Crank and carrier are crucial although I suppose you may be able to align hone the carrier to work with a different crank or vice versa.
The low mileage case I bought to rebuild had cylinder damage that made it unusable for a re-ring, but not enough damage it wouldn’t be rebuildable by LN. The seller let me keep it so I’ll probably give that one to LN.
Looking with the bore scope, the rod was not visibly bent, and there was no visible damage to the crank carrier. I am hoping I got lucky, but will definitely check everything!
Silber
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
