did the op of this thread find the solution to his brake system issues?
I'm having same issues of rear brakes locking up and cannot bleed the system,
thinking to replace the original rubber brake lines... then look at abs pump, then maybe booster though it's acting properly..
my test for the booster? turn off car, pump the brake and it would go from 3/4 travel, second pump 1/2 the travel, third pump of the brakes 1/3 travel.... suspect it's not the booster
i have 2000 boxster S with 65,000 miles on it
blow out abs pump is the next step
