			Re trans mount change:
 Okay, perhaps one loose trans mount at a time, with a couple 2x4s side by side (for load distribution) in between the jack and trans case (at the mount pick up section; same loaded section) is a reasonable "at your own judgement and risk" proposition
 JFP I completely understand what you can recommend and what you need to stay away from.....
				__________________986 00S
