Old 09-09-2021, 09:23 PM   #2
elgyqc
elgyqc's Avatar
Originally Posted by john12312 View Post
Whoever suggested that must not like you. Any google search on jacking up a Boxster from underneath the car will provide guidance and none will tell you to use the oil pan as a support.
It was not me who did this, the cracks where evidently there when I bought the car three years ago. I hope no one is foolish enough to jack up the car using the engine sump... but some people suggest supporting the engine with a jack under the sump.
From the Pelican Parts site technical articles:
"Replacement of the mounts couldn't be easier... Gently place the floor jack under the engine sump, taking care to only apply enough pressure to relieve tension on the front mount... "
Note that this article does not even suggest using a block of wood between the jack and the sump.
Grant
