Old 09-07-2021, 05:54 AM   #3
ike84
Agreed with quad, that doesn't make any sense. When these injectors fall they tend to stick open, but that's no reason why they should leak with the rail still assembled... Unless that's just fuel running out from the rail where the return line was disconnected and down the injectors by gravity.
I didn't try but Wayne's writeup says o ring replacement can be tricky (it's easy to damage the tips). You may just wanna swap to all new 986.2 injectors.
Sent from my SM-G970U1 using Tapatalk
