Old 09-03-2021, 04:11 PM   #7
kamran66
Ok, I wanted to post this as a positive fix so others don't end up replacing a bunch of parts. My driver's side window dropped but wouldn't go back up, I removed the door cover and checked the regulator and switches, I even replaced the door latch but the final fix was the window motor....not the regulator, only the motor. I think it was due to jumping the car after the battery died, this may have damaged the window motor's control board. The motor worked fine it was just not hiking it up the last 1/4 of an inch after the door was closed. The new motor fixed it.
kamran66 is offline   Reply With Quote
