Old 09-01-2021, 08:49 PM   #4
blue62
Originally Posted by ike84 View Post
I just wanted to make sure that it is the nbo2 sensors that, as you said, serve as a witness to the MAF data and not the other way around.
Correct me if I'm wrong, but our cars will still operate with the maf disconnected, which is why I questioned that.
You don't happen to know the trigger/threshold voltages on the nbo2 sensor readout that actually causes the fueling changes, do you? I've studied the different voltage vs AFR plots and the curve's temperature dependence, but I haven't been able to find any hard number about the ecu's thresholds for reversing the fuel trend.
The below pic came from a Bosch pdf, but they have inconveniently omitted the axis scales. The other chart is an actual plot, but no info on what sensor was used or at what temp. My best to guess is .7 and .25 are the thresholds based on overlaying trust two charts.
Can you guess why a tinkerer such as my self would be interested in this info? I'll give you a hint, there's more power at 14.2 than there is at 14.7
Sent from my SM-G970U1 using Tapatalk
First:
O2 sensors "do not" serve as witness to MAF data.
They serve witness to what the DME is doing with fuel.... in an indirect manner.
O2 sensors compare oxygen in the exhaust to oxygen in the atmosphere.
From that comparison a small voltage is produced. That is the only thing they are capable of.
Yes our cars will run with the MAF unplugged.
The DME will default to open loop and use default fueling maps.
Threshold voltage:
Stoichiometric= 14.7-1 fuel/air ratio "by weight" which is represented by .450mv on a NBO2 sensor.
Above .450mv is rich
Below .450mv is lean
In simple terms what happens is:
From a precaluculated set point "14.7-1 fuel/air" on a fuel map.
The DME will add fuel until the O2 sensor voltage crosses the .450mv. "Threshold"
It will then start taking away fuel until the O2 sensor voltage falls and again crosses the .450mv "threshold".
Then it will start adding fuel again to drive the O2 sensor voltage back up across the
the .450 threshold.
So on average the fueling strategy is Stoichiometric. 14.7-1 Fuel/air
Depending on the manufacture, model, year, etc. etc.
This happens around 3-10 times per second.
The above is in very simple terms.
What is happening is why I say the O2 sensor just bares witness to what the DME is doing and that the DME drives the O2 sensor signal.
The O2 sensor voltage range of the sensor used in our cars ranges from around .100mv - .950mv
I look at all sensors as witnesses to an event and the DME/ECU as the Judge.
The witnesses report to the judge and the judge makes engine management decisions based on the witnesses testimony.
Like all witnesses they are either telling the truth. (So the sensor is not the issue in relation to a fault code). Or they are lying...(faulty sensor).
Thinking this way is just part of my diagnostic methodology.
Yes I am well aware of fuel air ratios and their affects on power.
If your wanting to tweak fueling and and watch AFR's you want to install wideband lamda sensors. They actually sense fuel air ratios not just oxygen.
NB O2 sensors are only accurate at Stoichiometric 14.7-1 AFR so very poor for what your looking to do.
The number one reason the DME/ECU has the fueling strategy it has... is so the Catalytic converter performs properly and has long life.
The second reason is fuel economy.
What you and I call performance falls third.
The first two things are mandated by federal law
The third.... Performance... is just a bonus
Your graph on the left (the brown one) is voltage "mv" on the left and fuel/air ratio on the bottom
Look across the bottom tell you find 14.7 go up and the O2 sensor signal will be intersecting .450mv on the scale at the left.
blue62 is offline   Reply With Quote
