Old 08-29-2021, 08:17 PM   #2
pilot4fn
In that case, yes, it could very well be rolling toward the front of the car with the driveway slope. Otherwise, although highly unlikely, it could be one of the tubes running to the front of the car.
I had this weekend a small leak pretty much in same location as the OP has, showing mostly at the under the front of the engine bellypan. Also a small amount of water dripped little more forward (maybe under the seats location) as I was racing at the track.
Had to retire before last two starts and took the car home driving it... while keeping cabin heater on HOT sertting and selecting only highway roads to allow coolant to stay relateively cool - I have a low temp thermostat.
No leaks on the way home for 110km and temp stayed low.
Opened the bellypan under the engine and found out the leak coming from water temperature sensor, but only when the water was at normal or higher operating temperature and the water pressure was high.
Boxster 2.7 2001 Manual
pilot4fn is online now   Reply With Quote
