Old 08-29-2021, 02:55 PM   #1
blue62
VK,
Sounds like it could be the water (coolant) pump.
Once you get it in the air and remove the body under panels you will be able to get eyes on it.
The coolant at the front could be from coolant running along a hose or on the body under panels.
I have looked at your blog.
I see your not afraid of something like this.
you will be able to do this repair no problem.
You just need to get "eyes on" the leak so you know if it is hoses or water pump.
Once you identify the problem you will have no issues.
