Old 08-28-2021, 02:01 PM   #1
blue62
Originally Posted by vkmotorsports View Post
I went and purchased the Harbor Freight radiator pressure test kit and will try it out.
Agree that I want to find the cause first before trying out solutions.
Thank you.
From what I can tell in your picture I am looking at the the area where the aluminum pan (brace) and the plastic under body trays meet.
Remove that plastic under body tray and you should see where a number of coolant hoses meet up.
Then top your coolant system off with distilled water and pressurize the system with your tester. You should have no problem finding your leak..
Once it is repaired then us the tester to again pressurize the system so you can make sure everything is ok.
