Old 08-28-2021, 11:10 AM   #1
blue62
Originally Posted by vkmotorsports View Post
is water pump failure causing the leak or is the process of fixing the leak an opportunity to also replace the water pump ?
First thing to do is a visual inspection of the suspected area of the leak.
If you find nothing obvious (like a leaking hose).
Then get a coolant system pressure tester.
Places like Harbour freight have them for a reasonable price.
You can test just about any coolant system with them as well as the coolant cap.
With the test kit is it easy to find leaks in coolant systems.
People will say change this or change that. That is Poor way to do things.
Find the cause of the problem then fix the problem.
