Old 08-25-2021, 06:31 AM   #1
Starter986
1998 Boxster Silver/Red
Originally Posted by Oldcarguy View Post
. . . in my case anyway. In 2018 I cleaned the radiators & ac condensers and fabricated grill guards for all three front openings for my 2004 Boxster. The grill guards were fabricated from power coated aluminum grill stock with a 77% open surface area. Mounted from behind the bumper cover, the cooling openings were 100% covered. There’s an old thread about my fabrication and installation here somewhere.
After installation of my 3.8L engine I decided to remove the bumper just to do a preventive maintenance of check the radiators & condensers. What I found surprised me. While not as bad as in 2018, I did find significant pulverized buildup between the radiators and condensers.
Because it’s obvious that I’ll still need to clean these areas every two or three years I removed the grills to restore 100% flow. Pics below of the grill material used and the pulverized material found between the radiators and condensers during my inspection in July 2021.
Are you driving on 20th century highways... or dusty backroads and chicken ranches?
I used the metal mesh from HD... mounted from behind the cover... check the rads/conds every year (with cover off), and zero debris sans a few things that get caught up from underneath. Have you considered a smaller mesh?
1998 Porsche Boxster
