Old 08-24-2021, 12:25 PM   #3
ike84
The 3.2 and 3.4 stock fuel maps utilize different sized maf housing sizes. If you are using the 3.2 MAF housing, your DME is thinking that you are moving MUCH more air than you actually are, hence the rich running. Replaced the MAF housing with a 3.25" diameter housing and this should fix it.
What aftermarket injectors is it running? If it is a bosch, just double check the flow rates to ensure they are equal. I forget off the top of my head but I wanna say the stock rate is 240cc/min (thats for the 2.7, 3.2, and 3.4). I run the 03-04 MY injectors on my 2000 and they work flawlessly with a stock 996 tune and 3.25" MAF housing.
Edit - I just reread that again. If you're running a 3.2 tune, your 3.2 maf housing should be correct b sorry about that.
Have you measured afrs at all? And are you running in open or closed loop when this is happening? (Any elm/obd logger should be able to tell you that). If you're in closed loop operations (which you should be at idle) and the exhaust o2 sensors are the same from when your last motor died, they may be driving your problem.
On a side note, is would be very careful about running a 3.2 tune on a 3.4. When you go WOT be and you kick into open loop mode (supposing that there is one still with the flash) you may go lean. Again, a wbo2 would be helpful there.
