Old 08-21-2021, 03:42 PM   #16
elav
Thanks for the advice of this board but seeing as I already had the new ignition assembly, I decided to replace the entire ignition assembly. You have to remove the headlight switch, side panel, tumbler and instrument cluster (which is some work) but once you do that - it is a pretty straightforward effort. Took a couple of hours.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is offline   Reply With Quote
