Old 08-17-2021, 06:47 AM   #13
Qingdao
Qingdao's Avatar
Originally Posted by ike84 View Post
Sorry, that comment was directed at Gilles - I've not heard of adding a ps cooler before and would love to know more about it (setup, advantages, etc).
Sent from my SM-G970U1 using Tapatalk
Lots of GM trucks use power steering coolers factory. I don't think its really necessary for a little sports car that doens't put much strain on the power steering system. On a HEAVY chevy front end that does a lot of low speed turning; yeah that pump is doing some hard work.
Cooler is a stretch; its more like a section of pipe that has some fins on it.
Toss a thermometer in you P/S reservoir and that'll give you an idea whether or not a cooler is necessary. I'd imagine most of the heat in the power steering system is from heat soak from the engine though; so I don't think a cooler would help that much. (this is of course if you are using a belt driven pump in the engine bay)
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
