Old 08-16-2021, 06:40 PM   #1
jaykay
jaykay's Avatar
Originally Posted by Quadcammer View Post
Thanks jaykay. I do have a bend as the lines go through the bulkhead and into the rack, but the are gentle bends. The lines do go up a bit from the reservoir but others have seemingly done the same without issue. I may just have a bad pump as others have said the pump should not draw anywhere near that many amps
Okay if the car is sitting and the pump is drawing too many amps you have the culprit.
Try to get the pump the Porsche cup cars use in there......ah its got to be unnerving to have a change in steering feedback on banking!! I dont track my Boxster any more but high speed turn-in feel was a problem for me ....probably more on the psychological/confidence side rather than dangerous understeer.
It would be good to see images of your set up.
986 00S
