Old 08-15-2021, 02:26 PM   #297
Escy
Originally Posted by ike84 View Post
I'm not sure if I said it on here already so if I have please forgive, but I don't like the idea of using wmi to fix a problem. The issue there is that of you run dry or your system malfunctions, it may cost you a motor. I'm certainly not trying to criticize your setup, I think you've done a fantastic job.
Sent from my SM-G970U1 using Tapatalk
I've got a level sensor wired into my screen wash light so I'll know when it runs low and have got a flow sensor which will flag an error if a pipe came off (set up as a boost cut) and also I have knock control which will pull timing so I don't consider it much of a risk.
Escy is offline   Reply With Quote
