Old 08-15-2021, 07:51 AM   #293
ike84
You are right, his setup is at low boost. The m96 is not setup well for anything over 5-7 psi. He did not do a detailed build documentation unfortunately, and he seems to have built a lot of walls around himself as he has become more successful so I can't seem to figure out how to reach him.
It's all about balance though. Air or water, you're never gonna have cool intake temps with 30psi boost. You pick your poison, so to speak.
Where do you charge pipes sit? You could put small bar and plate intercoolers in line on either side if they line up with the side vents. Put some scoops over the vents to really shoot air through them. There was a twin turbo boxster (if you can call it that) that used a V8 from a 968 which was setup like that, albeit their "side vents" were massive.
Sent from my SM-G970U1 using Tapatalk
