Old 08-13-2021, 02:00 PM   #16
mikehkang
Yes that is correct. It is on the plug.
What I was referring to is:
If you pull the plugs to check them as part of your maintenance schedule.
Then replace them (because they look fine). You need a new crush washer.
In days gone-by: You pulled your plugs, cleaned and gaped them every time you dressed and gaped your points and set your dwell.
(about every 30000-35000 miles)
So you replaced the crush washers every time you cleaned gaped and reused your plugs.
Back then the washers were very easy to come by. I would have 20-30 in the tool box.
Not easy to find them now days.
I have a schedule for all maintenance items on my cars.
But I also let the car tell me what it needs.
Example:
I have oil changes on a 5000 mile schedule.
But if the oil is discolored or dirty when I check it with only 2000 miles on it I change it.
Perhaps there is a business opportunity there - sell crush washers on Amazon.
How are you checking the oil discoloration? There is not much oil on the dip stick. From the filter housing maybe?
mikehkang is offline   Reply With Quote
