Old 08-11-2021, 09:37 PM   #2
junglegreen
I replaced the left side door lock mechanism with the URO part (thanks Pelican) and now there are no faults in the Alarm system per the Autel scan tool. I have only turned the key ON and have not gone for a drive or put the top up since the lock install.
The lights still behave the same way. When I open the door the interior lights do not turn on unless the key is turned. Also, the radio turns off if I remove the key (doors closed).
Any thoughts on what else could be causing the interior light issue?
junglegreen is offline   Reply With Quote
