Old 08-10-2021, 07:54 AM   #20
ike84
the injectors for the 2.7, 3.2, and 3.4 are all the same from 00 - 02. the dme just runs them on different duty cycles to adjust for different fueling needs.
these injectors are no longer being made. they were a special part made by bosch specifcally for porsche. you can remove yours and send them out for cleaning and testing (which costs about $30 per injector plus shipping), buy a remanufactured set from a company called reman, or do the 986.2 injector swap. If youre worried about the injectors, I recommend the latter - you can get them for $25 a piece and the modification takes less than 5 min per injector with a dremmel.
before you do this though, do as blue says - repeat your vac test. if your vac is still low then you haven't fixed your problem. bad injectors dont cause low vac pressure.
