Old 08-10-2021, 05:55 AM   #27
blue62
Originally Posted by colacharlie View Post
Hi all. Vacuum test complete plus a smoke test and small leaks found and O rings renewed, plus fuel pressure test complete and all in range and spot on. Car runs a bit better but still judders and is still horrible. I’m going to buy a set of injectors (second hand) for my 2.7 2002 and wonder if someone might know the product code of the injectors? Ps I have no access to the car Atm
Sorry don't know the product codes for injectors.
Ike84 or STL-986 will probably know
I take it your test for exhaust restriction tested ok?
Did you see if your CEL works??
I can also be tested with your Durametric.
Did you do another vacuum test after you found the small vacuum leaks
to see if it brought the vacuum readings up??
