Old 08-10-2021, 05:55 AM   #15
blue62
Originally Posted by colacharlie View Post
Hi all. Vacuum test complete plus a smoke test and small leaks found and O rings renewed, plus fuel pressure test complete and all in range and spot on. Car runs a bit better but still judders and is still horrible. I’m going to buy a set of injectors (second hand) for my 2.7 2002 and wonder if someone might know the product code of the injectors? Ps I have no access to the car Atm
Sorry don't know the product codes for injectors.
Ike84 or STL-986 will probably know
I take it your test for exhaust restriction tested ok?
Did you see if your CEL works??
I can also be tested with your Durametric.
Did you do another vacuum test after you found the small vacuum leaks
to see if it brought the vacuum readings up??
blue62 is offline   Reply With Quote
