Old 08-09-2021, 04:42 AM   #11
itsnotanova
Originally Posted by mikehkang View Post
A rubber hose!?!? This is what came off. What size rubber hose would I need? How did you secure it?
The accordion plastic hose is heat shrink wrapped onto the fitting. Take a razor to where it goes over the fitting. Only cut far enough down to remove the tube and not down into the barbed fitting. Take the fitting to any automotive store that has rubber hoses and you should be able to find a size that fits. Don't use a thin walled rubber hose like a garden hose. Something with some meat to it. The hose you get should fit on snuggly to the fittings. I can't remember if I used hose clamps or not. 30 minute job tops
Woody
