Old 08-08-2021, 08:54 PM   #11
blue62
Originally Posted by ike84 View Post
Post 21 - he's pointing at the check valve and says " I'm not sure where this goes". I took that to mean he found it disconnected from the runner, meaning that he has a vac leak. I'm not trying to argue with anyone, just trying to save the guy some potentially unnecessary hassle.
Sent from my SM-G970U1 using Tapatalk
So from his pictures I made a few assumptions.
1. He is in England and in his video he is driving from the right side of the car so it is a European spec car.
So no SAI system. So no spot to put a vacuum gauge like a U.S. spec. car which has a vacuum port on the front crossover tube left side near the throttle body. In plain view.
2. I assume he took things apart looking for a place to connect the vacuum gauge.
I believe he found the vacuum port for the EVAP system which I think is on the front crossover tube right hand side on the bottom. Out of plain view. So as he moved and turned the rubber collar over the check valve came out.
Not assumptions:
1.He has no EVAP system related codes. Which he should have because if the check valve were out of the vacuum port then the EVAP system could not get vacuum so would fail the first EVAP test by the DME/ECU and would set a code.
So most likely he was not running with the check valve unplugged from the vacuum port.
2.Even if the check valve were missing from the vacuum port the vacuum leak would be from a hole about an 1/8"th -1/4" in diameter. Very doubtful that would cause his issue.
Also if I understand your thoughts correctly your saying there is a possible problem with a vacuum leak where the check valve is supposed to go.
So how would you test your theory????
Put everything back the way it is supposed to go. Then test drive the car???
If that fixed the problem great.
But if the problem is still there he would have to go through the work of getting back into the engine bay, accessing the vacuum port and doing the vacuum test.
That is a lot of extra work to run a simple test. Do it while your there.
