Old 08-08-2021, 03:45 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
I am in no rush. I created a setup for adding heated seats using the factory switches to either factory seats or adding aftermarket seat heaters. Finally found out the factory relay under the seat is actually a microchip, which makes sense. What I would like is a set of switches and the wiring that hopefully just go to each seat heater relay, but that wiring is most likely part of a bigger harness.
I have a car I need to add my setup to but am out of switches at the moment & harness.
I'll get a good look at it in the next week and figure out how much of the harness I can pull without getting deep into the main loom. I'll let you know.
