Old 08-08-2021, 02:27 PM   #1
Stl-986
Yes and no. I pulled two seat frames out of it that were heated seats and have the wiring, but that car did not have heated seats as an option. I have an '01 that I plan to strip next month that does have the heated seat option and I can pull much of the harness from that car ---probably in a few weeks.
I am in no rush. I created a setup for adding heated seats using the factory switches to either factory seats or adding aftermarket seat heaters. Finally found out the factory relay under the seat is actually a microchip, which makes sense. What I would like is a set of switches and the wiring that hopefully just go to each seat heater relay, but that wiring is most likely part of a bigger harness.
I have a car I need to add my setup to but am out of switches at the moment & harness.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
