Old 08-06-2021, 08:58 AM   #10
Stl-986
You really should read through my post about driving off a cliff. Will explain a lot as well as show you what goes where, where to put your vacuum gauge, what the devices are, etc.
That black/white device is a 1 way check valve. It does in the hole in your 2nd picture. Plug that back in. Also reconnect the upper AOS hose.
Once that is all re-connected, connect your Vacuum gauge & T to the white side of the check valve and the other into into the factory T.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
