Old 08-04-2021, 04:23 PM   #4
P_Carfahrer
Pathological Tinkerer
I just installed them on my car and setting initial ride height according to the Ohlins instructions leaves about 3/4 inch of additional thread on the shock bodies that you could use to lift the car more to minimize the drop.
On the inner rear assembly in this picture you can see the color gradient change at the lower end of the threaded section. This is the amount you could potentially lift the car more. Using this all up however will limit your corner balance adjustability.
These are amazing by the way.
P_Carfahrer is offline   Reply With Quote
