Yes I am connected to the line going to fuel regulator . After my heads cracked I put the motor together by one of the articles on how to install cams .It is done with the tensioners out .They get put in in later steps .I checked timing marks and every looked ok .I just read an article where I guess I should of done it differently so I am going to attempt to set the timing with the motor in the car.Any suggestion how to do it successfully ? Thank you guys.
