Old 07-29-2021, 11:21 AM   #2
Homeoboxter
Hello Colacharlie, I am Not an expert, but since you are removing the cams the valves will be closed, and rotating the crank should not cause any damage to the valve train... It would be interesting to hear more comments from people with more experience.
Agreed. Without cams the valves won`t be opened. You need to pull and hold the chain aside so it won`t get jammed in the crankcase while someone else slowly rotates the crankshaft. Pull the plugs to make it easier to turn the crank.
EDIT: now that I`ve reread what you wrote, I`m not sure if you replaced the camshafts. If so, I`d pull the whole assembly off, rotate the crankshaft to TDC and put everything back on.
