Thread: P1123/1125 cel
Old 07-28-2021, 08:16 PM   #23
blue62
I just hooked up my Durametric and checked the Actual values list for the 5.2 DME.
You are correct it doesn't list post cat O2 sensors.
It is a very limited actual values list.
So you could try clicking on the 7.2 DME module and see what readings you get when you click on things like the O2 sensors behind the cats.
Or fuel trims. Just play around and see if it reads any of the values.
But run the test like I said in the post #22 I should be able to tell you if your Pre cat O2 sensors are working correctly or not.
