Old 07-28-2021, 05:15 PM   #142
Stl-986
RedTele58's post got me thinking (dangerous thing). I'm not too sure it is a connector issue, but it could still be a wiring issue, but this is where I need help understanding the wiring & coils.
When looking at the diagram the coil has 3 wires. 1 is +12v, 2 is ground. 3 goes to 42 welding point WL Motor, which I think goes to a relay if I am reading things right. The same ground is shared with coil 1-3, SAI pump motor & engine intake cooling fan motor. This ground is located right by the AOS & the outside corner of the intake manifold. Verified that it has 5 ground wires.
So, big question. If I disconnect that ground wire from the engine, should that wire still have ground connectivity? If I am reading the diagram right I dont think it should.
My question is if the gp 12 is disconnected from the motor, should there still be ground connectivity between those ground wires and ground?
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
