Old 07-28-2021, 10:39 AM   #19
john12312
2002 Boxster S
I'll let JFP chime in with some insight, he always has good thoughts. But would look into what he does mention about the oil pump.
Your last oil change, how much did you put in? seeing any oil leaks on the engine itself underneath?
My first thought is a lifter issue. Depends on the noise cause it could also be the cam pads/chains, but that is usually persistent not just on startup. I would put something in like seafoam right before your next oil change. Such as drive it for 20-40 miles with seafoam and then change your oil & filter. Let the oil drain for an hour and then fill. If it helps then maybe do it 1 more time.
I added 9.25 QTS MB 1 10w 40 Syn adding 9 then checking the levels I add the other quarter. The attached pic shows the spots I see underneath. I assumed it was old oil on the engine block with A/C condensation but I could be wrong. I've only seen a full oil drop once this year and the rest of the time this. The paper was new about 45 days ago.
2002 Boxster S 6 spd manual Arctic Silver
john12312 is online now   Reply With Quote
