Old 07-28-2021, 10:26 AM   #17
JFP in PA
I'll let JFP chime in with some insight, he always has good thoughts. But would look into what he does mention about the oil pump.
Your last oil change, how much did you put in? seeing any oil leaks on the engine itself underneath?
My first thought is a lifter issue. Depends on the noise cause it could also be the cam pads/chains, but that is usually persistent not just on startup. I would put something in like seafoam right before your next oil change. Such as drive it for 20-40 miles with seafoam and then change your oil & filter. Let the oil drain for an hour and then fill. If it helps then maybe do it 1 more time.
He needs to know the oiling system is functioning properly before looking elsewhere. It can be a lifter issue, these cars are prone to having lifter problems, but as for using the additive you mention, I am not even going to go there.................
