Old 07-27-2021, 05:45 PM   #19
elgyqc
elgyqc's Avatar
Those deviations are right on the edge of spec. Spec is +/- 6 Still good, but really, really close. Didn't happen to change the cam actuator pads while you had it out did you?
No, I thought about it but decided to install the engine as I received it, after some verifications.The plan is to do the pads on the original engine and put it back in the car, then I will go through this one.
Grant
