Thread: Bumper opinions
Old 07-24-2021, 09:13 PM   #11
RedTele58
RedTele58's Avatar
azlvr - if you're wanting to go with the front end that you want, this is the way to do it. I've said here several times before, and a year or so ago I nominated it to the Pelican best build contest - this is the best looking build on the 986 board and it has the exact front cover that you're looking at.
I'm not saying the bumper cover looks bad - it's a very good look - it just has to be in proportion to the rest of the car. JBauer has put countless hours into his car since he first posted about it 4-5 years ago. And he's also posted numerous trial/error pictures of things that he tried that just didn't have the right look. The Z-top adds balance to the rear of the car so the front bumper isn't overpowering the rest of the car and he's changed the look of the headlights so they blend into the flow and the lines of the front cover. Even the larger "987 look" intake vents help add the proper balance to the car drawing your eye towards the rear and a more balanced look.
Watching this car built over the past years has been a lesson in how to do something the right way. Everything he's done here has a very "factory OEM" look to it. All the things that I don't like on a stock 986 - the big front bumper, 19" wheels, the turn signals down low, etc are absolutely perfect looking here. The reason it all looks perfect is because the entire car is in balance, and it took a lot of trial/error for it to look this way.
So again, I'm not dogging you - I promise. I'm just saying this GT2-type cover isn't the right look on a standard looking 986. The car has to look in balance, and JBauer is the only guy I've seen do it right. And he did it most awesomely!
