Originally Posted by ike84
There is a grommet behind the battery that goes through the front firewall. That's the way from the frunk into the cockpit. From there run it back along the center console, tucked under the carpet, or along the door sill, whichever you prefer. From there go under the carpet on top of the engine bay cover. At the very rear bulkhead, you will find that the holes along the top communicate with the trunk. Just fish the wire through and voila.
Sent from my SM-G970U1 using Tapatalk
Yes I believe I have seen the positive battery cable connection go through this grommet. must lead to the big 80 amp current distribution terminal block on the inside....
Any tips for uncovering the passenger door sill route? the floor carpet seems to be really stuck in there.
