Old 11-02-2006, 07:04 AM   #16
JackG
Originally Posted by MNBoxster
Hi,
Actually, I'm not so sure. I believe it's the same picture, only from a different angle. There is only one 'U' shaped (sort of) cross member under the car, and it is clearly shown in both pics. I raise my car similarly to the pic shown from the Rainy Day website, but this is the same area described in the 2nd pic...
Happy Motoring!... Jim'99
Sorry, but that's wrong, Jim. There are two U shaped members under the car... the rear axle support with the steel cable loop, which is the correct jack point, and the little cross member just in front of the muffler, which is the one shown in the rainy day photo. Heck, the rainy day photo even describes it as the one just in front of the muffler, which is wrong.
I suspect you didn't get under your Boxster and look around, or it would be clear and obvious that there are two places that could be mistaken for each other. Think of them as the front and rear attachment points for the sheet metal brace (the flat pan) that covers the rear section of the car. The rear attachment point is just in front of the muffler to a small cross member. The front attachment point is at the axle support where the cable loop is. Each has two bolts. The front point, between the wheels, on the front end of the sheet metal brace, far away from the muffler, is the correct jack point.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
