Thread: Car Dies
Old 07-19-2021, 06:15 AM   #11
blue62
Originally Posted by gabedrummin View Post
The fuel filter was done when the heads were replaced .Sorry I have done so much work to this car I forget somethings . I did test gas pedal and the software says it correct . How do you reset the gas pedal ?
To recalibrate e-gas pedal:
With car setting level.
Disconnect the battery for 15-20 minutes this will allow the ECU to drop learned settings.
Reconnect battery.
Turn key to on position for 1 minute.
Do not start.... do not touch the gas pedal.
Turn key off for at least 10 seconds.
Start car.
After you start the car it can take a few minutes for idle to settle in and smooth out because the ECU is relearning some settings.
Take it for a drive and see how it acts.
Let me know if it changes anything.
