Thread: Car Dies
Old 07-18-2021, 02:15 PM   #10
blue62
Originally Posted by gabedrummin View Post
I have durametrics software .When I got the car it had a Porsche replacement, the original had an ims issue . This motor had low oil pressure when I got it so I replaced it . Car idle is normal at 700 rpm . The tac dose not hunt , rpm is steady. With the software it fluctuates between 700 and 740. If I accelerate slowly it will accelerate with no problems . If I push the pedal rapidly it bogs and runs poorly until the rpm is above 1000 to 1500 when I pull my foot off the pedal rpm drops below 300 for a few seconds then returns to normal at 700 . And some times it will die .It will immediately restart and idle normal .Thank you guys for the help.
Sounds a bit like fuel delivery issues.
Once your at 1000-1500 RPM will it accelerate normally to wide open throttle.????
regardless of whether you accelerate fast or slow???
You may want to do a fuel pressure test at the fuel rail and a fuel volume flow test.
Those tests will tell you if there is a problem with the fuel pump or fuel delivery to the injectors.
Vacuum test is still a good idea so we can start to rule some things out.
When was the fuel filter changed last???
Have you recalibrated the E-gas pedal???
Also look at your throttle position with the Duremetric. work the gas pedal with the Durametric hooked up and see if the signal % open seems right. things like 50% or near when you hold the gas pedal half to the floor. 3/4 pedal to the floor =75 % or close on the software.
