Thread: Car Dies
Old 07-18-2021, 12:56 PM   #1
gabedrummin
gabedrummin's Avatar
I have durametrics software .When I got the car it had a Porsche replacement, the original had an ims issue . This motor had low oil pressure when I got it so I replaced it . Car idle is normal at 700 rpm . The tac dose not hunt , rpm is steady. With the software it fluctuates between 700 and 740. If I accelerate slowly it will accelerate with no problems . If I push the pedal rapidly it bogs and runs poorly until the rpm is above 1000 to 1500 when I pull my foot off the pedal rpm drops below 300 for a few seconds then returns to normal at 700 . And some times it will die .It will immediately restart and idle normal .Thank you guys for the help.
gabedrummin is offline   Reply With Quote
